If you have homelink (or maybe even if you don't) you might want to consider a remote harness like this:
http://www.ebay.com/itm/KAWELL-1-Leg-Plug-Play-Remote-Control-Wiring-Harness-Switch-Flashing-Mode-300W-/181687741568?hash=item2a4d6eec80
Eliminates having to run wiring to the interior and finding a spot for a new switch.
+1 I did this and it was really easy to wire. One thing i found out is that the dual harness has both legs come on at the same time. You can't have the sides operate independently of each other
Sent from my SM-G900V using Tapatalk
I ran it through the nipple on the main rubber grommit that the majority of the wiring is going from the engine bay to the cab. Just had to get a utility knife and cut a slit in it and ran a hanger through. Taped the wires to the hanger and pulled them through.
Kerrslight, I think I know, but can you confirm where exactly the "main rubber grommet" is on these 1500 5.3 (2015) trucks?
I have multiple opinions and am hesitant to just start shoving coat hangers thru and risk damage.
Thanks!!
Dave
  • 7 months later...
This is where I put my main two switches.
Where did you get the bezel for those switches?
Sent from my HTC One_M8 using Tapatalk
Here's mine. Only three switches, but enough for me. Current running a light bar with two blanks for future expansion.
  • Like 6
Yes, a light bar in a '17 with active shutters! There's about 65mm of clearance. You can't go too wide, unless it's curved. I did a 16" triple row, straight non-curved bar.
What brand of light bar?
Where did you get that piece for the center console?
What brand of light at did you use and do you have any pics from the install?
    Enduro73
    Enduro73
  • Who's Online   5 Members, 0 Anonymous, 1,228 Guests (See full list)
