2" + body lift recommendations?
Hey all! really wanting a more higher body to slap on 35's.
i currently have a 4" Fabtech Suspension lift. With Uniball UCA.
The truck looks a bit higher than like a Denali. So im looking into a body lift now. something with a 2" to get me to 6" in total hight.
anyone know of a good brand to go with so i wont fall into any problems of cheap parts breaking on me. i know zone offers a 1.5" i think. And if your aware of any further down the road issues of a body lift affecting the truck or ride or anything in that sort please let me know, im really new to this new truck world and suspension world! so dont be harsh :P
Let me know what you guys have to offer! thanks! :happysad:
Truck specs.
FABTECH 4" suspension lift uniball UCA.
33's. tire
18'' rims.
-10 offset ( i believe so )
K&N CAI
MBRP Catback.
  • 3 weeks later...
Do you have any pics of this BL on his Silverado?
PM me your email or phone number. I have several shots he has sent me. Easier to send than to upload to photo bucket and then to here
upload them if you can, there are not a lot of pictures of trucks with body lifts on here. a lot of people request pics.
Owner of the truck would prefer that I not post them, however said that emailing them to anyone interested is fine. So to respect his wishes, I can't upload them. Sorry
Okay so im dead set on getting a 3" or a 2.5" body lift.. i live in canada so i need some canadian prices or stores. can't seem to find anything online.
currently got a 4" suspention lift from fabtech
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 839 Guests (See full list)
