input from everyone please
I've been talking to a company and been giving them ideas for custom badgeing that I want.. but I wanted to hear everyone's input and ideas. From what I've seen this motor of our is a EcoTec3.. so these motors are not vortec anymore? Anyways I have a 6.2 and I want to hear any cool ideas anybody has.. I'm kind of embarrassed to say what I came up with..
I REALLY want to hear what youve come up with now...
I DO TOO!!
I know I'm gonna get bashed for this
emblempros will do them in any color...
color scheme?
Thats way better than you made it sound like it was gonna be. How about just something simple tho. Like maybe badge it with stingray emblems. After all, it is basically the same engine/trans. If i saw a silverado stingray, it would get my attention!
How about a "LS3" badge? I would definitely change out my "LTZ" badge for a "LS3" badge, especially if they were the same font and size/look. Anyone with photoshop should give that a shot. I'd pass on the EcoTech3 badge unless you make it like the Duramax badge. That'd be cool.
The 6.2 would look good where this 6.6 is. Then you could put "EcoTech LS3"?
These are cool.
One more
Bob
What brand of short whip antenna did you install, and how has your reception changed? Thanks in advance.
Bob
to those that say LS3... it isn't a LS3... not even close to an LS3.
If you have to have custom emblems I would go with a simple 6.2 emblem and that's it. I myself don't care for emblems that much. I like very simple and clean vehicles.
It's an AntennaX - so it's big enough to get good reception but small enough to not whip around...haven't had any problems at all with reception
Bob
Bob
That kinda looks like the badge on the raptor.. maybe I'm wrong
Yeah I knew that these weren't the ls3.. but do you know if there even called the vortec anymore?.. if not then back to the drawing board
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
