What is this cable
Herd Thinners
Hood latch release? Could be anything on these trucks.
there is 2 wires there, I know exactly where it is (it is also where I ran my forward camera wires)
one of them for sure is for hood latch, the other one, it is probably the hood close/open sensor wire if I remembered it correctly
