I love the rear slider. If you're driving on the highway with the side window(s) open, you sometimes get some weird air pressure issues in the cab.  Open the rear slider lets the air move through the cab freely and gets ride of the noise and pressure issues.
I’ve Got a 2018 Gmc and am on the second leaking sliding rear window. The first time when they were replacing it I asked if it could be done, and was told I couldn’t because it would set off the body controls module?? Can anyone confirm if removing the slider affected anything?? I have never used mine and like the look of the solid wonder better not to mention no leaks is a bonus.
  • 11 months later...
i would like to thank mkwambold for his help replacing my solid glass rear window to a rear glass slider, his instructions & diagrams were just what i needed to complete the job without any issues. Thanks again.
I have a 2021 GMC Sierra crew cab with a solid rear window, want to replace with a sliding power window
How much and where to get it done ?
thanks
    xdieselmechanic
    xdieselmechanic
  • Who's Online   1 Member, 0 Anonymous, 603 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
