I have these code when I scanned my truck anyone know what they are
SAKO79
have you done any mods to your truck, like hid headlights. p0100 is a mass flow air sensor code which would also give you the b2aaa, which is related to the catalytic converters.p2700 is a tranny solenoid problem which maybe cause by p0500 which is the vehicle speed sensor
None of them are real codes per GM SI documentation. None of them come up. NONE.
OP needs to have the dealer read it with GDS2 to get the codes properly.
Mine had the P0100 code at delivery. The mass air sensor was not connected properly.
I plugged it in until it clicked, cleared codes , been fine ever since.
P0101 through P0103 are maf codes. Have never seen a P0100 on a GM vehicle. At least with a good scanner, ie: Tech2, GDS, GDS2
Any half way decent OBD II scanner will display the code definition in addition to the code on its screen. Only the cheapest of scanners display the code only.
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 454 Guests (See full list)
