Flowmaster 50 series HD muffler
Hi everyone, I'm new here and was hoping for some help. I have a 2011 silverado 2500 HD 6.0L and was looking to replace just the muffler. I like the stock setup 3.5" from manifolds back and also like the placement and look of the stock tailpipe. I was looking at Flowmaster and called them about there 40 series part #853548. The tech had told me with the 6.0L it would be very aggressive and warned me about just how aggressive it would be, then he reccommended the 50 series HD muffler 3.5" In/Out w/ offset part #853558. Could anyone comment on this muffler, or have any input on alternatives?
Many Thanks
  • 3 weeks later...
Do you know if there is much drone with the Magnaflow? I've been reading a bit through the forum and am getting mixed answers some saying yes some saying no??
You would be much better off with the Magnaflow. The Flowmaster mufflers are the most restrictive on the market, more restrictive and power robbing than the giant OEM one that comes stock.
Do yourself a favor and go with the Magnaflow.
Good to know.
Thanks, gonna check out magnaflow
Magnaflow, Borla, MBRP, Corsa, Corsa db are all fine exhaust systems and all produce a nice aggressive sound. All made from quality stainless steel, can't go wrong with either IMO. It really comes down to sound, personal preference really.
I have the Borla (GMPP) performance system on my 08 L76 V-Max, & MBRP on my 5.3L, both sound great.
Sent from my crappy iPhone 6
using Tapatalk
Flowmaster and Magnaflow are two of the only companies that make a muffler that will fit in the stock place. Most of the other manufacturers have bullet or resonator style 3.5" mufflers and you'll have to alter the pipes as well to make them fit.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
