Beautiful Color Matched Front Emblem
I didn't even know we had a forum store, but I found these awesome inserts.
Super easy to install (under 15 minutes) and they really change the front of the truck.
I did nick the chrome a bit when I started drilling the "C" because I was too close to the side. Rookie mistake. Don't be scared off though. Just don't get the drill too close to the side like I did and you will have no issue. It bites pretty much instantly and only takes a few rotations to drill out the rivet.
You can see the nicks in the last photo. I linked a smaller thumbnail but you can click to blow it up.
The "G" is not smudged or scratched, that is just weird lighting. The letters were flawless out of the package and color matched perfectly.
I definitely recommend these to anyone for a cheap and unique mod that will instantly set you apart from everyone else with minimal work.
OOPS!
looks great! I did the same mod, well worth it!
I wish the chevy ones were in colors!! :M16:
I checked with our supplier, and we offer everything they do for the pickups.
Sweet you finally got your truck (or I may have just noticed lol)! I remember you had a couple threads while you were overseas or something.
Sent from my SM-G900P using Tapatalk
Yes, thanks for noticing lol. I picked it up on July 27, drove it around Michigan, then out here to Kalifornia. Love the truck, everything went perfectly.
Well hell, I'm only 6 months behind lol! Glad you are liking the new truck.
Oh well...
Well, that's OK...at least there is ONE mod that I've seen on here that I won't be doing! lol :)
OOPS!
Awesome review. Your truck looks great. Glad you are happy about your purchase. We would be thrilled if you would review the product in our store!
We do as well. It's my understanding that it is a licensing issue with GM and nobody is allowed to offer color matched bowtie's for 2014+.
We would be happy to help if anyone has any questions on the billet emblems. Just send me a PM, jump on the store's live chat, or call us at 1-866-420-2216. :thumbs:
  • 4 years later...
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 534 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
