CB antenna thru Cowl
I remember seeing a mount for the CB Antenna to be mounted opposite the Radio Antenna.....comes up thru the Cowl.....can't seem to find it now, any help would be appreciated. I used to have a Bed Stake Mount on my '13 Silverado, but my new '15 Sierra Stake Holes are covered.....it's a Lease, so I gotta be careful.....if I go thru the Cowl, a body plug will likely go unnoticed when I turn it back in. I was considering a Fender Mount that mounts inside the Fender, and sticks out from under the Hood, but don't care for that look. Open to other options also. :cheers:
  • 1 month later...
I have a trunk lid mount on my hood (driver side). no holes to drill. any two-way radio shop can set you up. also check out www. Walcott cb.com ,www. breedlove.com , www. pL-259.com
  • 1 year later...
Leases are always tricky. As for the stakebed mount, the back ones are already open, or cut both of the front ones out. Should not effect your lease, especially at turn-in.
