HELP OEM NAV IN LT SILVERADO NON BOSE
WickedZ71
Hi,
I have an 09 Silverado LT z71 extra can short bed that is a non Bose. I found a like new oem navigation head unit with the conversion harness and need to find out if I can do the upgraded oem nav on a LT without Bose. I've read that a dealer may have to program the vin into the head unit. Any help would be greatly appreciated as I'd hate to have hundreds invested in a paper weight. What else would I need and where would I get the parts and pieces? Thank you for any guidance
Have you looked at the Advent OGM-1 head unit? Depending on how much that factory unit you have located is, it may be worth looking at. It will drop right in where the stock head unit was, requires no adapters, and requires no dealer visit. Not sure on current pricing, contact Walt here from ADC.
^^^ That would be the route I'd be taking. To hell with a trip to the dealer!
The unit I found is 500 Obo it's a denso unit.
On the sticker which is on the unit there's a series of letters and numbers a six digit UYS-UL8.
And then a 8 digit number next to a small GM logo. That number is 22870863. Another below that is another series of numbers
DW468100-7172. The seller also has the wiring harness and it is in great shape. Does any of this information help? Or should I still go with the OGM?
Looking at ADC website I see that the OGM1 has been discontinued. They recommend the CS-GM1210-US unit, that looks like the OGM1 spec wise. It is listed at $795. I have no experience with this head unit, but, if it is anything like the OGM1 head unit, it will do all that you want it to, easily. If you currently have the stock basic radio in your truck now (ie no Bose), this one will simply plug in using existing harness connectors, and will work out of box with your steering wheel controls, handsfree bluetooth(will add bluetooth if you do not already have it as well), and give you turn by turn navigation and a bunch of other things that I do not actually use or have need for myself. This head unit looks just like factory as well. The OGM1 was the head unit that dealers around where I am would put in if you wanted factory nav installed in the off the lot new truck you just bought that did not have it. They would tell the customer it was not the factory head unit as well.
$800 plus taxes and shipping for something you can pop in on your own with zero wiring changes seems to be a bargain to me compared to something you may have to modify your wiring for, then take to dealer and convince them you did not steal the head unit that is installed with a different VIN programmed into it.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
