Dash going crazy on startup...
flyboyron
This video below is what happens with my 2009 Silverado at startup in the morning when it is colder than 50 degrees. This will last about 3 - 4 minutes and then never happen again all day no matter how many times it is started. The colder it is the more the lights flash and will take up to 5 - 6 minutes before slowing down and quit acting up. One morning it was 28 degrees out and they flash fast and the gauge needles jumped more often.
When you approach the truck first thing the gauges are all still and lights are off. Once you hit the door remote, the gauges start to jiggle a little and a clicking noise, just as heard on the following video is heard.
After I insert the key and start it, the video shows what happens.
You can also see if you watch the first part of the video, the gauges are moving before I turn the key on and also just as I turn the key....they are jiggling. They will do that until I start the vehicle. I opened the door one time and closed it, then came back 10 min later, and the gauges were still jiggling.
I have had the battery replaced.
Both Positive and Negative battery cables replaced.
The dealer has had it a few days and is still trying to figure out what is wrong because of the short time span this happens. Once it quits, it doesn't do it all day.
They talk about voltages going to the instrument cluster, and are still investigating that route.
I was also told that replacing the cluster is $1,000.00. I found a video on YouTube where they remove the cluster in less than 10 minutes, and if I looked up the correct part at the different GM parts sites the cluster is around $200.00.
So I don't know what is going on here.
Any areas to suggest them to look?
Here is the video...
Ahh the joys of electronics! So great when they work, but boy do they go haywire when they don't!
Sorry I don't have a concrete answer for ya, but I'm shocked the cluster is only $200. I'd have figured a missing zero on that price ...
Clusters on Ebay go for about $200. Given that it is purely temperature, related my guess would be a cold solder connection. Problem is finding it. Since all gauges are moving, it looks like it will be either the power or ground circuit for the cluster. Try to isolate the source of the clicking. May be a relay, and you may be able to trace back from it to where the issue is. Cold solder connection issues have been a problem since they started soldering connections. Does not really matter how complex the system is, there are only so many serviceable parts involved here. Think of it like each part has a job to do, you don't need to know how it does it, just what it does, and what tells it to do that.
You will need a wiring diagram, digital VOM, and some understanding of DC circuits. Loose or poor ground connections tend to be the most common cause of automotive electrical issues for some reason. When temperature becomes a factor, loose connection becomes more common.
    JimmyB4
    JimmyB4
  • Who's Online   5 Members, 0 Anonymous, 774 Guests (See full list)
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
