back up Camera
Hello, just wondering if there is away to keep your backup camera on all the time, so what step would you take for this to happen if possible. Thanks in advance.
last truck had a camera with the image on an Edge CTS. I could turn it on and leave it on for hooking up the trailer. Is easier then waiting for it to turn on when put in reverse when pulling forward and backing up to get lined up. Also I could leave it on for a bit to just watch that the hitch wasn't binding etc. Didn't leave it on for long, but I liked having the option.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
