Newbie from mexico! Silverado v8 2015!
Jinez
Hey guys my name is Juan I live in aguascalientes, mexico and I just got a '15 Silverado work truck single cab with the 5.3 engine and 2WD, I used to have a Ford F-150 5.4 lariat 4x4 that I kept stock but now that i have my new truck and I've researched about the LS style engine I would like to mod it on the looks and mildly on the performance...
-first of all I got some 2" lowering shackles from Amazon, I've read good things about this and I decided to buy and install them...
Before and after (picture on top is the after)...
- I ordered a magnaflow glass pack of 3" and 22" length and I removed the big muffler and the resonator, as well as the flap valve (there's a little drone when it goes to V4 but I can deal with it, when the radio is on and the windows up so there's no problem)
Feels more agile and it sounds really sporty and not that loud.
- I also painted the rear wheel wells with duplicolor bed liner coating...
-also I used duplicolor removable paint to give a little change on the interior trim...
It's just a subtle change from black to silver (looks kinda dark but when the sun hits directly to the trim it looks really good)
- and finally I got the oem remote from Amazon and took it to the dealer just to have keyless entry enabled and it works really good and add a lot of convenience to my truck!
As for my future plans I want to color match all of the black trim like the grill, bumpers, handles and side mirrors (I wanted to do it straight off the dealer but my buddy is on vacation so I will wait for him), get some wheels, more low and I want to upgrade my sound system!
I hope you like my truck and mods!
Thanks in advance!
Saludos
Enviado desde mi iPhone utilizando Tapatalk
Welcome to the group, good looking truck!!
Thank you so much Steve!
Welcome to the group. Great looking truck and great post!
Thanks man!
Welcome
Thanks!
What makes that a 2500 in mexico?
In Mexico the entry level it's called Silverado and there are two kinds of Silverado, the 1500 (V6) and the 2500 (V8) after that it comes the Cheyenne that is more expensive and add all the convenience packages, chrome grill and bumpers, wheels, etc!
Saludos!
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
