Corsa Catback Swap
Hey Guys,
Anyone in the Jacksonville FL area interested in trading a stock exhaust for a Corsa ? Alternatively, anyone know where I can find stock exhaust for the 6.2L?
My Corsa is like new and came with my truck (dealer installed), but its a bit louder than I would prefer and I don't have a stock unit to replace it with.
Here is the exhaust info
http://www.corsaperformance.com/viewpart.aspx?year=2015&make=GMC&model=Sierra+Denali&tf=Polished&body=Crew+Cab%2fShort+Bed&partnum=14866&cfg=1606
I also would be willing to trade my OEM blacked out wheels for some OEM polished aluminum ones. I want to go back to the stock look and sound.
Peej,
I would be interested but currently have 5.3. Don't know if 6.1 & 5.3 are interchangeable? I have 2014, I'm in Orlando.
Peej,
No they will not interchange.
RT
I still have my stock muffler and flapper but cut the rest off and tossed it to make room in the garage.
If you decide on being willing to ship I'd love to work something out. Mines a 6.2 and has 2700 miles on it.
RT
Thanks for the info, I imagine the 5.3L exhaust is not 4"
It's my daily so I could only ship if, one, you were willing to cover the cost and, two, you can ship yours out first. I realize this is kind of unreasonable, hence the preference to swap locally.
Message sent to you.
