Front diff regear
Lol oooooook u were talking about need new carrier in the front if have 3.08 but direct swap with 3.42. Jesus sorry guys, I got all kinds of confused in there
Sent from my SM-G900W8 using Tapatalk
Hahaha yes that is exactly what i was talking about.
Glad we are om the same page now... I was like wut?? Lol
Sent from my Note 4 on Tapashit
I dunno what happened and how I missed that. Lolol, home from work in 10 days, gonna hit up the shop and get a quote and ask if they will power train that like my lift
Im doing the same....got quoted $1800 front and back installed 4.10s with the new carrier for the front.... I have 3.08s :(
Whenever they decide here at work that i can go home.
I'm. In Canada so I'll assume around that CDN without needing new front carrier ...damn shitty CDN dollar
Its a very good deal.... If i order the gears myself from eastcoastgearsupply.com thats what they come out to..... And this shop will install them for that.
They did the 4.11s on my colorado and i have bashed that thing for over 80K on and off the track with drag radials spraying off the line and they hold up so i am confident.
I'm hoping shop has a Canadian hookup, parts alone. Will cost me at least 2 grand with shipping and exhale easy. Let alone labor
Just looked into Yukon gear in Canada, they have a lot of Canadian distributors, 2just a few hrs from my city so that's good news
Get to calling tomorrow!!! Haha
All i could find on youkon's website was for the front diff..... What about the rear?? I didn't see any ring and pinion options for the 9.5" gm rear
Rear end u have to go to a new carrier. Yukon gear has it. That east gear supply there ( sorry drawing a blank) has the full kit that I'll need instead of buying individual. Need ring/pinion, new (old style) carrier, cover spacer and new yoke.
You'll need**
You'll need**
No.... Its the front that needs the new carrier not the rear. And that is only if you are coming from 3.08s....3.42s and up u dont need it
Thats what eastcoastgear told me
Both eastcoast gear website says need new carrier and rednecks write up when he called about it says need new carrier for anything over 3.73.
That's where we got mixed up before lol? I thought u were talking rear when u were saying that.
Everything everywhere for the rear says anything higher than a 3.73 you have to swap carriers. There is NO direct swap as of yet for the new style 9.5 rear ends
This.
Which means you have to go with the old 14 bolt carrier for the REAR. The front differential I have no idea, but like I said, it should be the exact same as previous gen trucks. I used the same carrier up front in my 02 when I went from 3.73 to 4.88 if that helps anyone at all
No, AAM has a 4,10 gearset that fits a 3.42 carrier in the new 9.5" 12 bolt. If you want lower than 4.10, you may have an adventure. The 3.73 limit is for the 9.76" 12 bolt.
http://www.demandaam.com/axle-results?vm=GM&q=9.5%22+12+Bolt+-+Rear+Axle
this is why I am taking it to a shop.....
I have no idea.... I thought the new carrier was only for the front and that's if you had the 3.08s
CLINTD....where R U! I know he did 4.56s but am curious as to what all was involved.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 0 Anonymous, 721 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
