2014 max tow package
I have a 2014 high country. What would i need to change to make it have the max tow? I currently have the tow package and integrated brake controller, i am assuming i have the trans cooler since i have the tow package.
Sent from my SM-G900P using Tapatalk
If your truck is a 6.2 it has the 9.76" rear end regardless of Max tow or not. The shocks are different but springs is debatable. Someone on here a while ago bought the "max tow" leaf springs and gained absolutely nothing as they looked identical and sagged the same amount as the originals did with the same load applied.
Im gonna do airlift load helpers, gears i wouldnt mind changing to 3:73. My 01 suburban had them. If thats the only difference why wouldnt they offer it. Smh
Aftermarket shocks and a set of airbags is a much better setup than the OEM stuff anyway. I'd advise that for the suspension instead of NHT parts.
The NHT radiator, part# 23126402 goes for around $550. It should be a straight swap as all the other parts seem to be the same, but I can't confirm.
That just leaves you with gears. 3.73 is what the NHT had, personally I'd choose 4.10's instead but I don't know if anybody makes them for the 9.76" yet.
Thx, just cant see why they wouldnt offer it. Love the truck and cant afford to trade in. Wouldnt mind spending a little to keep it
The 9.76" is really limited as the aftermarket has nothing... and with it used so little in the grand scheme I doubt it ever will. I should see if I could just swap the 9.5" guts in the housing.... then do whatever I want. Or buy an entire 9.5" and swap the whole rear end.
Sent from my SM-G900W8 using Tapatalk
I was thinking a swap would be better if u find one from a junkyarf
It is. But although I want 3.73s with my 8 speed I would rather have a Detroit locker.... which to be honest isn't made yet for either ring gear size.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
