Pinion side shot posted. Looking at it, there is little pointing up which is where it needs to be.
Any chance you can attach your camera to the rear axle facing forward? Its hard to tell in the video but it almost looks like there isn't any vibration going on in the drive-line and its all in the body. I'm curious if the same shake will happen in the video if you have it on the axle. I wonder if clamping the springs making them stiffer is helping restrain the vibration;
edit: I've had a suspicion for a while a lot of the roughness and vibration is happening from the front and the stiff frame is transferring it to the rear of the truck since it has the least amount of mass.
Edited by ic3man5
Is this your truck KLRV6?
Are you saying the pinion angle is correct and yet you still have the vibe? Just trying to decipher this. Thanks!
Yes it is my truck. The pinion working angle is out of spec. 3.09 degrees difference and it needs to be .25 - 1 degrees. So, a 2 degree shim would make it 1.09 degrees, which is much better than where it is now. If needed and it wouldn't upset the front too much, I can adjust the rest out at the transfer case. It wouldn't take much more to get it around .75 degrees. Yes, it's good to have an angle, but this is way off and it can get enough movement from the suspension moving up and down to keep the u-joints lubricated.
I already have one of the rear. I'll post it tomorrow. There is so much going on with the suspension.
Awesome, thanks for your insight on the matter! Hopefully the shims will help for you! When do you plan on having them installed?
Awesome, looking forward to seeing it.
The truck is on week three at the dealer. If they don't take care of it. I will once I get it back. They informed me the other day that they have had to keep one of their customers trucks for three months and still couldn't fix the vibe.
I can guarantee that truck sat in the parking lot for 10 of 12 weeks and just said they were working on it the whole time, ain't no way GM would authorize that much reimbursement for warranty work
They had one that 80 hours was "invested" in and GM paid for 10. I call them every day or two and request a status update. I understand things take time. If they let it sit, that when my tolerance runs out. My truck was there two and a half weeks before they even looked into the complaint I had about the transmission whine.
So I clamped 5 inches behind the axle. It stiffened it up and bumps feel horrible but it seems to have taken some of the "extra vibes / noise" out of the drive. With clamped behind the axle, what does that do with pinion angle?
I am thinking there is lots of resonance coming from the suspension
It will point the pinion down, so more of a negative angle
Sorry it took so long to get posted. 2015 Silverado rear view at highway speeds
. It was a rough week at work. I did get my truck back and the vibration is gone at highway speeds. I am cautiously optimistic about the repairs being permanent. The dealer performed the transfer case update, replaced ring/pinion and bearings, replaced two rear shocks - one had completely failed and had oil leaking out of the top. This is a non-Z82 truck.
I will get another video at the same view with the repairs made.
I will get one of the camera attached to the axle.
So what is the verdict on tightening the U-bolts/adding another clamp to the leafs? IMO, the last thing anyone on this forum wants to do is start screwing with the pinion angles and the driveshaft; you'll never get it shimmed just right, and you'll make yourself crazy trying to do it. The pinion angles are also not going to affect high-speed vibration as much as they will affect the low speed shudders. To be honest, I think the fix for these trucks is going to be a custom made one-piece driveshaft, but I have a lease, and I'm not putting that much effort into it.
I am waiting to see if the current repairs have resolved the issue. If vibration comes back, I may take the driveshaft out and have it checked by a specialist.
what exactly did you do?
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
