So you are running E85 on a vehicle not suited to run on it?
I'm running E85 in my 2015 5.3 without the FFV option. It runs it EXACTLY as I have experienced in previous FFV trucks and as others have reported on the 14+ FFV 5.3s. It is more responsive, smoother, shifts better, and seems to have more power. It is getting approx 20% less MPG, which means it is adjusting fuel injection for the increased ethanol content.
Can you go look at the RPO codes on your glovebox and tell us if you have either or both of these RPO codes?
FHO
FHS
In a nutshell, yes.
FHO
FHS
It has FHO but does not have FHS. This is a 2015 Sierra DC, 4x4, SLE with the 5.3, if that matters.
FHO is to use E10, FHS is is E85
Yeah, I wouldn't be running E85. The FHS option provides an alcohol sensor & enables the correct tables in the ECM.
Without FHS it won't have the ethanol sensor.
For 2015 Sierra:
FHS NEW! E85 FlexFuel capable
- Included with (LV3) 4.3L EcoTec3 V6 engine. Available to order with (L83) 5.3L EcoTec3 V8 engine.
(In 2014 it was standard on 5.3 as well)
(In 2015 it is 0ptional with (L83) 5.3L EcoTec3 V8 engine with (MYC) 6-speed automatic transmission or included with (LV3) 4.3L EcoTec3 V6 engine.) ---- which means it is not available in combination with the 8 speed transmission
Edited by redwngr
... which means it is not available in combination with the 8 speed transmission
Wow, nice catch there.
Yes, I really wanted to add it to my 2016 (SLT/5.3/8spd/max tow) -- but it can't be done (through GM).
Just do the next potential owner of the truck a big favor if you keep running E85. Let them know you continuously ran E85 in the truck, even though its not E85 compatible. Theres more to it than having bigger injectors and pump.
  • 4 years later...
I know this is an old post, but I just rebuilt a 14 Silverado that was a total. I used a engine / chassis from a 15 Silverado that was a rollover but good straight frame. I used the 14 engine computer since it worked with the key from the 14 cab.  I have the code for the ethanol sensor because the 15 frame didn't use it.  My question is how to reprogram the ecm, or can it be to eliminate this code from staying on.  Or how could I add the sensor so the computer would see it.  I tried the 15 ecm and reprogramming the key but it didnt work.?? It put it in theft mode.  Do you have to use a new chip key for the key program to work? I was trying to reprogram the original key?  Runs perfect other than the check engine light on. I'm not in an emission county so doesnt bother me til it's time to sell.  Thanks
The 2015 computer doesn't work because it would require a full program flash to the match the PCM and TCM, then the key needs to be programmed.
The 2014 can be tuned with an aftermarket tuner to disable the flex fuel system and remove the codes.
Or you can steal the flex fuel sensor and hard line off the 2014 frame and install it back on the 2015 frame. Or buy a new sensor, plumb it in near the fuel tank and extend the wiring to reach it.
    LCH14
    LCH14
  • Who's Online   5 Members, 0 Anonymous, 957 Guests (See full list)
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
    • With this new pan, do you still use the same procedure to check the level? Its a deeper pan and our trucks do not have a fill tube/dipstick. So fill till fluid runs out the check plug?
