Headlight led strips
Jeff5347
OK so I know this may not be for everyone. After getting the truck I was envious of the gmc's upper and lower led rows, so I bought a set of cheap white led strips and installed them below the headlights between the valance. I really liked it and thought it looked good but being cheap LEDs the pass side quit working. So I would like to have something again but don't feel like going thru removing the grill and headlights again to make them fit. Curious on you guys that like LEDs where they may look the best. I get some will think they're stupid thats why I'm only asking them that like them
Sent from my Nexus 6P using Tapatalk
  • Replies 36
That was my thought. I found some led strips that give off a real nice white but you can see the circuitry which is not nice to the eye or ascetics..like this
Putco makes some real nice LEDs but at 150 I'm gonna still see if I can find the strips with the circuitry covered
I was unhappy with the Putco ones and Putco customer service. Very slow to respond to my emails to warranty them
Did they blow out too? The design I like but I feel I can get that same result but cheaper
If you are careful (and patient) you could tape off the LED diodes then paint the strip flat black so the circuitry is covered. Then install them like the Putcos and they should look similar.
^^^^ thats a good idea. I could def do that and be patient at it. My only concern is another " moving part" to fail as in the paint chipping due to aging and the bend on the headlight
looks good!
id love to have some led running lights like the gmc's but id want to do it so the projector is off and just the led lights come on. i figured thats not possible since its all controled by the bcm no?
How I did my strip below the headlight was a silicone or something encased strip. The were side emitting diodes. At 15 bucks for the set it was a more proof of concept for me to see how they look as they said water resistant and although I put them in in November and had plenty of rain, snow and sleet on them lasted well for getting wet. To get them under there I had to remove the grill, bumper strip and headlights. Really not that hard minus being super careful with the bumper strip to not damage or crack it.
I had a maxima a few years ago and opened the headlights and placed led strips inside so I had no worries of water damage but I really don't wanna crack open brand spankin new headlights.
So do I find better, whiter, waterproof side emitters and redo what I had? Do I make it easy and make vertical ones that go between the headlight and grille?
Maybe a strip on each side between the bumper and bumper strip? Or????
Curious if one of these 3 places would look good. I wouldn't need to do much or any disassembly. Vertical seems the easiest but not sure on verticle???..
Between the bumper and bumper molding I like but not sure if its too low below the headlights???
Between or below the headlights will be your best bet. The other locations just look ricey IMO..
http://www.automotivelightstore.com/oracleconceptledstrips-1-1.aspx
I know ... Thats why I haven't done anything yet. The in between the headlights is how I really want to do it but just making it semi invisible up close is the problem.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
