Grade Braking
Today exiting off the interstate on a flat road, just coasting, the info center displayed a message saying "grade braking active" I was probably around 60 mph on flat road...any ideas why that would show up? 2015 Denali 6.2 with 3800 miles and first time I ever saw this.
were you in tow mode?
This happens often to me when driving in tow mode but mostly on hilly roads on the north shore of the island.
JC
Hmm... interesting but normal. Powertrain Grade Braking is on or armed if you will with each ignition cycle. Strange that it said it on a flat ground. Were you applying any sort of brake pedal pressure be it light or moderate? Typically when it sees light, constant pedal pressure, it will activate the grade braking.
Mine will come on with even the slightest down hill angle. What most people would consider flat ground. Only if i am coasting or lightly on the brakes.
There is also a 'cruise grade braking' function that can activate to keep the speed from climbing when in cruise on a downgrade.
Grade braking is activated when the brakes reach a specific temp . Really does not matter if your going down hill or not . If you ride the brakes just enough it will activate . It is not tow/haul mode specific either .
I don't think it has anything to do with brake temperature. Any literature I have read from GM says it can help keep the brakes 100 deg cooler but that is the only reference to brake temp. It monitors grade and brake application to activate.
"To disable or enable all grade braking within the current ignition key cycle, press and hold the Tow/Haul button for three seconds. This feature requires the driver to apply steady brake pedal pressure to maintain desired speed while driving on a downhill grade. The vehicle's modules calculate brake temperature and enable Normal mode Powertrain Grade Braking if necessary. The transmission downshifts and engine RPM increases. At this point, if the brake pedal is released, the transmission will hold the current gear. If additional engine/transmission braking is needed to help maintain desired speed, reapply steady brake pedal pressure and additional downshifts may occur"
http://www.acdelcotechconnect.com/pdf/TechConnect_SepOct_2013.pdf
So it's a calculated temperature then not an actual temperature of the brakes. The calculation is way off, -30 deg C and the grade braking comes on when there is no way in hell the brakes are the same temp when it's +25 deg C. Same road same speed everyday and grade braking comes on like clock work. I think GM is trying to make it sound a lot more technical than it really is. If it worked off of brake temperature and not "grade" it should be coming on during heavy braking in all conditions. I can't say this feature really does a whole lot, Just something we are paying for like the engine braking feature that is useless.
