Help confirm part numbers?
I need some help confirming I have the correct part numbers before I order these please.
It's the black window trim for a crew cab Sierra 1500.
Front driver: 23227165
Front passenger: 23227166
Rear driver: 23227174
Rear passenger: 23227175
Thanks for any help
Josh
Thanks for any help
Josh
I've been trying to find these as well. Where are you ordering them from?
Thanks!
I bought the complete set on EBAY from Bill Cramer Chevrolet/GMC in Florida, Had them in 3 days
EBAY item # 281933484819
179.96 for all 4 pieces
Thanks!
GMPartsDirect.com :)
I ordered the black window trim for my GMC and here is the message that GM Parts Direct sent me:
Hello and thank you for your order.
Unfortunately the parts you have requested do not match your vehicles VIN#.
Please tell us what you've needing to replace and we will find the correct part numbers to match what came standard with your truck.
Thank you and we are sorry for the inconvenience.
Hello and thank you for your order. [/size]Unfortunately the parts you have requested do not match your vehicles VIN#. [/size]Please tell us what you've needing to replace and we will find the correct part numbers to match what came standard with your truck.[/size]Thank you and we are sorry for the inconvenience.[/size]
Yeah, I ran into something very similar. If you forego entering your VIN, and just do it by part numbers, it'll work. That's why I wanted to ensure I had the correct part numbers.
Josh
I just installed these on my new 2016 silverado today and they fit perfectly
I should've purchased from your buyer. GMpartsDirect has really dropped the ball with my order.
Uh-oh what did they do?
I ordered mine on Wednesday and they shipped it today.
Definitely the correct part numbers. IF ordering from gmpartsdirect.com make sure to not input your current vin# if your purchasing black trim for chrome. My order was delayed a week because the parts didn't match my vin# and they wanted to confirm that I was indeed ordering the intended parts. I don't fault them for double checking that the parts were correct as much as the slow customer service response time.
How was the install?!?!
The install took about 45 minutes. Once you do the first the rest are easy...take your time getting the clips released, I used a plastic trim removal tool and it worked great. The only issue I had was the passenger rear trim piece didn't want to lock in place, really had to put some weight to it, the other three were easy.
