St. Louis
Just returned from St. Louis and the Childerns hospital there. My daughter had Selective Dorsal Rhysodomy surgery to help her walk. She has CP and man what a difference in just a few days after. That place is the best. Never seen such care in everyone before and all the latest equipment. Really made an impression on us and I tell you what, when it is your child on the the surgery table you want the best and this is the place for it. Dr. Park is the one that started this procedure and has perfected it to the T.  The man is great. It was a long 9 day visit, got to see the Arch and other sites. Oh and the Budweiser brewery was really cool. Talk about a ton of beer, man now there is a place that can brew some suds. Not to mention the tour is FREE.
So if any of you out there ever need medical treatment for your children, look into the Barn's Childrens hospital in St. Louis. It is top notch. It is good to be back home. No place like home. :thumb:
Now to get caught up on things around the house, the grass is so high. Yuck. If I could afford it Astro turf would be my lawn of choice.
Keep us updated as to how things go.  As I mentioned, my cousin had that surgery a few years back at the Cleveland Clinic.
Glad to hear that things went well...  Childrens Hospital is great!!!  I've had my son to the one in Pittsburgh several times for digeestive problems, and the people there are very genuine and really care about your childs health.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
