1995 4X4 tbi suburban
jonpdubois
Thanks JS... But it starts completely normal... Thats why I'm here... NOTHING strange or out of ordinary... I have another 95 suburban with same engine setup... Starter moves normally and smooth on both... No speed change in either...
Pull the valve covers then. However bad smell indicates fuel isn't being combusted so at least one cylinder... or all randomly is not firing.
Sent from my SM-G900W8 using Tapatalk
90 when the others are at 140 surely isn't going to make it run very smooth. Maybe not a dead miss, but it ain't good!
That would show up on the test... his engine compression is fine lol..
Have you unhooked the exhaust on the truck and run it?
The compression tester used is new... I figured there was a discrepancy with the tester and put it on my 96 350 vortech... Almost same readings... My 96 is the family daily driver and runs about 200 miles a day with no issues with 324k on the odometer... Don't think the gauge is flawed...
10-4 -- just figured I'd throw that out there, since we're troubleshooting over the net. So we've ruled out compression - that leaves fuel and spark.
Ok... Just so y'all know... I am an idiot... Now the miss became stable after i changed the distributor... And then I decided to change the plug wires with a little led flash light in the dark... 2 and 4 were swapped... Switched them to there proper plugs and it runs like a charm... Any way... Thankyou for all the help and assistance... Feel free to call me a moron... Lol, and have a good day or night, were ever your at.
And yes... The pickup in the old distributor was cracked...
I didn't even think of that, and that's a VERY common problem! I've done it myself a time or 2 - we're only human.
Glad you got that sorted out. :cheers:
Next question two 95 suburbans:
One two wheel drive w30(4L60E)
One 4X4 manual t-case and 4L60E
Swapping bodys, the two wheel drive harness will operate the 4 wheel frame right? Two wheel truck has bent frame, and 4 wheel has a wrecked body... And my wife loves this truck... To her 4X4 is an added bonus... I have done swaps before on some older vehicles...
Since it's non- OBD-II it should be pretty straightforward. You can always wire in the things needed for the front axle to engage. Can't remember if those used the vacuum system or electric solenoid to engage it ...
EDIT: you posted while I was typing - you can just wire up that solenoid to work on a toggle switch to keep things simple, or just cut those wires out of the other truck and use them the way they were originally.
Thats kinda what I had figured... I just don't want to disable a perfectly good and operating 4 wheel drive train... Lol... Let y'all know how it goes... Thanks...
I think most of the 4x4 related wiring you could leave right with the 4x4 frame/drivetrain - it only needs 12v from the ignition, and probably switched by a detent in the transfer case. Fairly simple compared to systems built this century.
I was actually going to suggest to verify plug wire installation, except I was thinking more of 5 and 7 being swapped.
Something that has not be said is that just because compression is good does not mean that engine is mechanically sound. You can be missing 95% of the camshaft lobe for an exhaust valve and still get good compression, but a miss when engine running. A compression test alone is really only good for verifying that there is no BIG sealing issues in the cylinder like a holed piston or burnt valve/seat. Otherwise the results are only a starting point in the diagnosis. Small block Chev engines in the late 70's to at least the mid 90's seemed to be tough on camshafts. Don't know how many I found by simply taking the oil fill cap off the cover and checking the rocker movement by using your finger through the hole on a running engine. The rocker on one side moved significantly more than the one on the other side. A common side effect of a bad cam was the engine backfiring through the intake under initial hard acceleration.
There was a post asking about the possibility of a valve being opened by compression due to weak or broken spring, that is not really a possibility due to relationship of valve to piston. Compression will actually push the valve into the valve seat. That is actually why the valve train is setup that way, otherwise the valves would be pushed open under pressure from the cylinder firing.
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
