Transmission filter change gave me error codes. Help please
Ben Girard
Hi,
I was swapping all fluids of my 2008 4wd silverado 5.3.
I did a drop the pan and filter change.
I measured about 5 quarts lost and put back about 5 quarts. I haven't been able to get a clean read of tranny oil level yet.
Tranny is sluggish in 1st gear and won't shift to 4th. It's throwing codes and when I clear them the truck runs fine for 3 seconds. The tranny is building a lot more heat than usual.
It gave me P0700, P0976.
Now P0976 is pending after I cleared everything twice and P0700 is still there.
Do you guys have any idea? Just improper fluid level I'm hoping.I only drove it 10 miles to go back home.
Thank you !!
In addition to fluid level, I'd be checking all the connectors on and around the tranny. Might have bumped one, or maybe one was left unplugged ... or not fully seated.
Especially near that bolt way up on top of the tranny - what a place to put something that needs to be removed to drop the pan ... :nonod:
We're you careful taking off the pan? Sometimes if you pry on the pan the wrong way you can mess up a solenoid...
dido on the solenoid. p0976 is a shift solenoid issue. pull the pan back off and inspect the wiring. Hopefully you just unplugged a solenoid and didn't break it. It happens.
We're you careful taking off the pan? Sometimes if you pry on the pan the wrong way you can mess up a selenoid...
^^^^ pretty common
I thought a P07xx was the only shift solenoid code. I had an P07 something something, when the 1-2 solenoid took a dump in my rolling lemon of a '00 Jimmy. I couldn't tell the difference between the 1-2 & the 2-3 solenoids, so I tested them one at a time - the one that caught fire with 12v applied was the culprit. :lol:
Learn something new every day with these electronic wonders.
Thank you for all your answers.
Not gonna lie getting that pan off is a major PITA. I removed the tranny shift link and pry on the exhaust as much as I could do.
The pan on the rear left side cleared not in the cleanest way possible ...
I didn't unconnect anything that I know of but I could have damaged somethimg for sure.
I'll check everything tomorrow.
One question, when I clear it everything is fine for 3-4 seconds, shifts into 4th gear. That is a good-ish sign right?
Edit : also that solenoid code was pending last time (you can see it on the attached picture in the initial post)
Alright I added a quart level is good.
Trans still slips bad in 1st gear and won't go in 4th. It's building heat fast too.
Still throwing the two codes.
I don't wanna open it and not be able to get parts today.
Do you guys think it's fine to drive home, 80 miles ? It's all highway and I'll take it easy for sure.
I've seen older transmissions burn up in 5 minutes when things are slipping - all depends on the severity of the slip. Generates some serious heat - not good. Only difference with the modern ones is the electronic controls - the mechanics of it are still basically the same.
I think you'll be left on the side of the road within 80 miles, for sure, unless you leave it in 3rd the entire trip with minimal stops - impossible on this side of the nation, but you may be able to do that in MN. You could need new frictions by the end of that trip. Total gamble, and tranny work ain't cheap. Your call there ... but if it were mine, I'd rather pay for an 80 mile tow than a rebuild on these newer ones.
I would either fix it where it sets or I would have it hauled back home. I would not drive it.
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
    • Injector is being sent off today for rebuild and I estimate I'll have it back in 10 days or so.   It may not be the injector...of course...now that I've torn down the intake again. But, let's rule out the injector and replace those spider legs that have been almost rubbed through.   The truck has always had negative timing and I'm reading "normal" timing at warm idle should be +16 or so. I'm negative 16 to 25 or more, and it's always been like that since I bought it.   A light turned on upstairs last night in the old noggin. Rare, I know...   This will be wild, if it turns out to be the cause!   In 2001, according to the old service documentation, the muffler was replaced. Why? I have no idea, it wouldn't have been rusted through by then. But they did a crappy job.   In 2019, another shop replaced it and noted the prior install was poorly done on the work order. "Exhaust system vibrates on crossmember". Except...I guess they just left it be? I believe the husband, the couple who were original owners, had passed by then. Maybe she said it's just not worth it to have the exhaust system fixed and declined repairs. Very few miles were driven between 2019 and 2025.   The exhaust system vibrates heavily on the crossmember and you can feel it and REALLY hear it, even today. Not always, but at idle, it gets going pretty good sometimes.   What if....   ....What if that's enough to trigger one or both of the knock sensors? Could it be tricking the sensors into sensing knock, so it's pulling timing aggressively? Pulling timing heavily means it's firing after the piston reaches full height which means incomplete burn which means the O2 sensor is sensing a rich condition, which means I've been chasing my tail, and what I thought was an inconsequential problem (janky exhaust) has been THE issue for this truck for 25 solid years?   That would be wild. Maybe it IS wild.   The service documentation thereafter, for years, shows visits for rough idle, replacing O2's, replacing the cat, replacing plugs and wires, a misfire condition, like they could never solve the issue. The injector has been replaced 4 times in 80k miles, that's just crazy.   The secondary theory....   The engine has clearly had a leak at the front seal for a very long time (the greasy trench...). I think the truck changed hands quickly ~2025 because there's Napa receipts from someone I don't recognize in the ownership history. They apparently replaced the timing cover seal, and they did a terrible job. There's RTV smeared all over and the leak I had reduced to a weep by snugging the front oil pan bolts is now a leak again.   HOWEVER....I read about replacing the crankshaft position sensor. Any time the ckp sensor is disturbed or timing cover is removed, the truck requires relearning, and that can only be done through a bi-directional scan tool. Skippy with the RTV probably didn't do the relearn procedure is my guess. His scan tool is lost in a pile of RTV goo somewhere.   So, it's very possible the sensor has been disturbed and the truck is just running on the old learn data but not setting a code for anything. The distributor has since been replaced and so has the camshaft position sensor, so all bets are off for that thing.   In the theme of one step forward, two steps back, I returned the accumulator for the AC. The gal I've been working with at O'Really's has been great. She refunded it under manufacturer's defect and we compared it to the replacement I ordered, and sure enough, the replacement is machined very differently (and a gauge actually fits on it!).   Got it home, installed it, started vacuuming it down.... and I couldn't get good vacuum.   The high side service port, where I replaced the old GM ball valve suspecting that was a source of the previous leak....well, I've clearly exposed whatever pre-existing crack in the line where the service port is welded, and made it much worse. Blessing in disguise? Except there goes another $25, now I'm waiting for a replacement AC line.   In 10-ish days ALL the parts will be here. Rebuilt injector, new exhaust system, new cat, new high pressure AC line.   Oh, did I mention the squeaking ISN'T coming from the AC pump? The truck still squeaks when started, and there were words after I started it with the new AC pump installed. But, there was more to replacing the AC pump for just a squeak. A truck with good working AC is something of value, for the comfort alone.   I've ordered a new harmonic balancer because, 30 years is a good run for one of those. Rule it out. The squeak may be something more sinister, though. I'm worried about that ckp sensor and if it was shimmed correctly, or if the timing set was installed correctly. The squeak may be coming from UNDER the timing cover.   At this point, once I get it put back together, I'm thinking I'll take a 50 mile victory lap and then promptly put it up for sale. This truck is cursed. Betty, from beyond the grave, doesn't want anyone messing with her Blazer. Or maybe she's getting revenge for 30 years of shop visits with that thing.
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
