Vinyl on black badges
Hey guys,
Ok so I put the vinyl on my truck and initial thoughts:
1) The vinyl looks sick
2) It also doesn't look super clean
Id suggest that if you want the look of it but don't know if you like it or not then just try the vinyl first so you can see it. Then if you like it just paint it like I'm going to :)
I like what I did to mine better because on the front with the chrome grille shell I didn't see any need for the chrome trim around the bowtie. Now if it's a color matched grille shell then the chrome trim would look better to separate the bowtie from the grille. I just bought replacement aluminum bowites that were painted. Sure they cost more, but I won't have to redo plastidip or anything. Plus it actually took less time to replace the pieces than it would to plastidip the stock inserts. For the front I did a full bowtie, so no chrome trim, just an all black one piece bowtie where the stock one went which looks good with the chrome grille shell. The rear I kept the chrome trim and put a black insert in the trim, so I just replaced the gold insert, not the whole thing.
Front:
Rear:
Hey guys,
No Billet Bowties. Do it right the first time
43fe2e96635aff103d683d94373dc6ef.jpg3936fde7781a209928f2d9922cd7c0ea.jpg had it like this for almost 2 years. Don't want anything on the tailgate tho
Front:
Rear:
How much did all that cost you ?
I can't remember right off the top of my head, but I want to say about $75 a piece. So like I said, wasn't cheap, but they're painted aluminum so I was willing to pay that much.
Same for the Z71 badges on the bed. I took the decals off and replaced them with the actual door emblems you see on a Midnight Edition or Custom Sport. So from a distance they look like the decals, but if the sun hits it right or you get up close you see it's actual badges. They were $40 a piece I believe but I was willing to pay that much also for them because everywhere I looked the regular decals were $20 a piece.
Oh shit thats nice! Im thinking of either doing that with the 4X4 or going with a black 4x4 sticker
Debage it. That's what's clean and nice... that's my opinion
UPDATE:
did the black back badge and still hate it hah time to paint it soon for sure. Good news though is they look ok as long as you don't get within 10 feet of it
When I bought mine back in '14 the site I got them from had all of the factory colors so you had no problem color matching them; but now all they have is chrome, black gloss (which is what I got) and black powder coat which I believe is more of a flat or satin black.
What site did you get them from?
I'd get billet ones. Worth the money IMO. I didn't pay for mine however. I Made the dealer pay and install them (had to get the last say in the deal!)
Damn I wish I would have done that! I want to plastidip them tomorrow but I also want them to be more reflective than the examples Ive seen.
Plastidip wont be glossy no matter how many coats of glossifier you use. Now that I have done mine in Plastidip and decided I like it I am ready for something more permanent so I am looking for color matched Oxford White .
    BrandonFranceschi
    BrandonFranceschi
  • Who's Online   4 Members, 1 Anonymous, 1,533 Guests (See full list)
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
