Professional info needed from pro's
Hii gm's
In brief, im planing to replace my 5.3l with 6.2l
Current: 2011 5.3 flex fuel lc9(3), 6spd.
Replace: 2010 6.2l not sure about the engine type. Any way to know the engine type code from the block it self??
The main thing is it a simple swap and reprogram ecu?? Or some other things must be done?
Thanks & regards..
  • 3 weeks later...
Hii
It seems like no one here did the swap before...
Ok i did it and wanted to share the info with you guys,
I did the swap and started the engine today and took my truck for road test and it was amaaaazing, so powerfull.
Ok about the swap:
4 things are diffrent between the engines mentioned.
-intake manifold
-fuel injectors
-engine starter
-converter pipe, but it can be used without replacing
All the rest parts are the same
And of course reprograme to a standerd 6.2 file or a dyno like i did.
Thats it and hope this info will be helpful...
What did the engine come out of? L9H is the truck engine
Ryan
It was taken from 2010 sierra denali, yes L9H is a truck engine
Im not sure if it is L9H or L94, but sure its not L92.
As i red in Wikipedia:
(...The L92 was modified with Flex Fuel capability for MY 2009 and became the L9H, and was further modified with Active Fuel Management for MY 2010 (and becoming the L94) in the Cadillac Escalade and GMC Yukon Denali's (interestingly, Active Fuel Management hardware was present in 2007 engines, but the software was not present in the PCM).The L92 started in 2007.
Here is the link i took the info from and it has alot many info about LS based GM small-block engine:
https://en.m.wikipedia.org/wiki/LS_based_GM_small-block_engine
If it was from a Denali it's not an L9H
Ryan
