What size KO2's is everyone running?
  • Replies 72
With larger (stock) rims, a narrow patch of rubber looks like a wagon wheel. :-) For all intensive purposes that's it - simply matching the look of the wheel to the rubber.
I think you've 275/60/20. Looking at your pic in another thread . You may want to go check. You could've ordered that size and your tire shop messed up.
Awesome!!! They just don't look like 305 in the other pic still need some pics of different angles. I'm so ready to give bgf $1,400 for some tires.
The pic in your "pron pic" is cooper tires so the tread and sidewall are different than the KO2's (obviously). I am very happy with the BFG KO2's so far...no regrets at all.
275 65 20 on an rc 2.5" level. no rub. This is on a 16 gmc sierra slt.
So is no one using the 285/65/20's?? Measures 34.5", and should fit with a 2.5 level
I plan to order a set next month, but I also like the look of the width on a 305/55 (33.2")
2 inch leveling kit. 275/65/20 KO2's, stock 20 inch wheels. Little rub at full lock in reverse. No problem-o
Do you have pics?
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 363 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
