2015 Silverado 2500HD, 1997 Camaro
ryanhardy
Hey guys, new user here! Just picked up this 15 silverado, I'll primarily use it as a winter driver for the rough winters up here in western NY, and I also have my 97 camaro as a daily in the summer. Second owner with a little over 14k on the clock. I've always wanted a truck, and this one came along at the right price. I may eventually get into some plow work as a side job, but I'm a little undecided right now. Which sounds crazy, because you might ask why i got a 2500 then, and it was simply because it was sitting right next to a 1500, with only 4k miles different, and they were the exact same price with the exact same options. Not looking to change it a lot, as I want it to remain mainly stock and reliable. At most things that won't void the warranty. It's already had a full undercoat and rustproofing HID lows, LED's for the other lights, toneau cover, and I'd also like to put some clearance lights, and some of the newer chrome tow mirrors on. Other than that, maybe an exhaust, and definitely a tune, So if there's any recommendations for that I would greatly appreciate it! I've been involved in a camaro forum for a while, so I know that "talk" but im still pretty green on silverado talk. My camaro is a fully optioned 97 z/28 that has been made into an SS clone. leather, power everything, T tops, 6 speed, 5.7L LT1, posi with 3.42 (stock gears) with some minor modifications, and just last year dynoed 337whp which isn't too bad for a motor that came stock with 275.
Personal life: I'm a full time college student, i work part time at a local grocery store (Wegmans for those of you in the north eastern area), and I'm also part of the US Navy Reserve, I'm 21, and yes I pay/ paid for both of these cars myself, NOT mommy and daddy which is what a lot of people assume when they see someone as young as I am with these vehicles. Feel free to ask any more questions as they come along, and ill try to upload some pictures of both vehicles
Glad to see another self-funded individual my age, we are a rare breed! Hang in there dude, college is a long haul but worth it!
Welcome from northern Michigan! 61 yrs young here. I also got a new 6.0 HD last Nov. havn't done much to it other than a soft bed cover. I got mine to pull our heavy arse TT, we are snowbirds & go to Fla. So getting a HD for us was a no brainer... It works sooo much better than my 14 1500 5.3 3:42 did. Congrats on your new truck & enjoy that Camaro! as we also have a scratch home built 72 SS.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
