2016 Silverado LTZ Front Bumper
So, I'm new to this forum and after having my 2016 Silverado LTZ for a little over 3 months.. I can honestly say I love it. Still thinking I should have went with the crew cab instead of the double cab, but I can work with it for now
After a little mishap the other day in a parking lot.. I ended up with a dent in my front bumper that pretty much looks like someone backed into it and imprinted there trailer receiver into my bumper. I pulled the bumper off yesterday and tried to straighten it back out but the metal is creased in the shape of a square and won't straighten out... Needless to say my truck looks like complete crap now (at least in my opinion).
After 3-4 days of research, I've come to the conclusion that parts for this truck seem to be impossible to find.. Is it because it's too new or what ??? Found one passenger side headlight on eBay for $1,000 and that was it!! Every GM part website I find won't even recognize my VIN.
I've joined this forum to see if anyone may have a factory take-off front bumper they were trying to get rid of, or know of anywhere I can get one from that won't cost an arm and a leg ?!? Lol
(And excuse me if I'm in the wrong section, if I am someone feel free to point me in the right direction)
Chrome bumper with fog lights and front park assist sensors 84029812
Chrome bumper with fog lights without front park assist sensors 84029801
Painted front bumper Z71 with fog lights and front park assist 84029814
Hope this helps!!
I am in the same Boat .. needing a black bumper for a 2014 High Country with sensors... looking for a used one but I think I am going to have to go with a new one ... Confused on what part number
Post or PM me your complete vin and I can look it up for you.
Looks like it is this number 22944857 for some reason the repairlink site states your vin is invalid but I got it figured out.
Will a 2015 2500 bumper bolt up to my 2015 1500???
Don't believe so
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
