Tuned 5.3 on E85
foo.c
When u refer to a blower as a "supporting mod" you MIGHT have a hp addiction lol
I have been running E85 for a few tanks and i live the way the truck feels. My tuner said if i ran strictly E85 he could pull more power out of it. But due to my work situation i dont know if E85 will be available in the areas i get sent to.
Sent from my Note 4 on Tapashit
Were you tuned with a Diablosport? If not, there shouldn't be any issues for you to be optimized for both E85 and regular gas.
HPTuners.
And a strict E85 diet would net better gains as i wouldnt be switching between 91/93 and E85 every few tanks.
I blame work.... And anyone North of where 91 is considered "primium" lol. back home we have 93 as primium but not as much availability of E85.... Up here E85 is scarce and 91 is the highest.....
But hey.. . Ill take what i can get lol
If you have it set up to run E85, the computer can tell what % of ethanol is in the fuel and adjusts accordingly. So if he tuned it for E85 then it will adjust to what he set it to.
Provided that there is an alcohol sensor, correct.
Beautiful part about the 2014s is that the E85 was a widely implemented option if it wasnt standard. Mine and my girls 2014s are flexfuels
The thing to keep in mind when using E85, is that you have to run a few miles right after fill up (~7-10) when switching between that and regular gas. If not, your computer will not be running the system efficiently.
On on a stock truck with the ethanol sensor, the programming will adjust tune the the % ethanol measured by the sensor.
I have no idea if any of them do, but a 'tuned' truck could also make use of the sensor.
Correct. Just not all of them have that sensor. We have already tuned a few folks who have turned their vehicles into Flex Fuel, so it is certainly an option.
Some flex fuels in the earlier years, did not have the sensor.
Ahh got ya. Learn something new everyday!!
2014 is when they started putting them back in.
    DWic
    DWic
  • Who's Online   5 Members, 0 Anonymous, 553 Guests (See full list)
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
