Tuned 5.3 on E85
foo.c
I wonder how much power this is making? I had BBP tune my truck for 91-93 octane and he said it would help on E85 as well.
Isn't the stock tune good for 380 on E85? I bet it's close to 400 with the tuning.
Anyway, I filled up on E85 for the first time since tuning, and the truck is running strong. Curious what the ballpark horsepower number is.
More HP but worse MPGs.
Who cares about MPG?? LOL
is all about smiles per gallon!!!
Sent from my Note 4 on Tapashit
MPG might be less but dollar per gallon, at least around here it is still cheaper to run E85. It is $1.40 a gallon where 93 is $2.43.
My 02 isn't a fexfuel vehicle and BB tuned for 93. When I run E85 it seems to run stronger. Plus I like the exhaust smell. :) Might convert it some day. Just need to get the sensor and larger injectors.
I have yet to find a dealer that will honor a warranty on a vehicle that has been tuned.
5.3, BBP tuning, E85. Just thought I would highlight the subject.
Anyway, I might be an alcoholic. I think it's worth the 20 minute drive to fill up twice a month.
And yeah the smell is different/better than pure gas, reminds me of a wedding reception with all the cans of sterno burning.
I am running E85, and am seeing around 750HP....but I have a few other supporting mods :driving:
When u refer to a blower as a "supporting mod" you MIGHT have a hp addiction lol
I have been running E85 for a few tanks and i live the way the truck feels. My tuner said if i ran strictly E85 he could pull more power out of it. But due to my work situation i dont know if E85 will be available in the areas i get sent to.
The thing to keep in mind when using E85, is that you have to run a few miles right after fill up (~7-10) when switching between that and regular gas. If not, your computer will not be running the system efficiently.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
