6in Lift Kit Recommendations
Have a black/black 16 LTZ71 double cab that I am considering lifting and putting on 20in wheels with 35in rubber. Been researching a lot of lift kits and have gotten a lot of dealer input on brands. They of course contradict each other depending on who they are reping so need do help. Here is what I'm considering:
Kit:
Pro Comp
Fabtech
BDS
Zone
Wheels:
Rockstar 2 20x9
Moto Metal MO962 20x9
Fuel Octane 20x9
Rubber:
BF KO2
Nitto G2
Daily driver mostly on highway with little to no off road so basically going for the look and not off road performance. With that said, it's still a new truck so quality still important.
Any input or pics of similar setups is appreciated. Thanks gents!
All of those brands have been around forever and make good kits. While offroad performance may not be high up on the list, ride comfort always is. You dont want to jack it up and have it feel like you are driving a mixer. Were you looking at the basic kits, or the ones with the coilover shocks?
Wheels it comes down to preference, I like the Moto wheels as well as the Octanes. We see a lot of Rockstars here in Vegas so I tend to steer people toward something different.
Nitto G2 is a softer tire than the KO2 and will ride better on the street, the KO2 will hold up a little better offroad.
We can get you setup with everything you need ready to install at a great price if you are still shopping around.
Just looking at basic kits but planned on upgrading the rear shocks. I am hesitant on the Rockstar 2s but have yet to see them on my truck in the Chicagoland area.
I just started seriously looking at kits but have been considering wheels/tires for a few months. Going to need a shop for the install so figured it made more sense to work a package deal to help cut on install labor cost.
Trying to be around $4-5k all in if possible which may be a stretch.
What do you think of the zone kits? Could I add the bds coils to that kit later down the road? 2015 gmc 1500 4x4. 6.5" and 35 mud grapplers on factory 20s
The ZONE kit is great. They do a ton of research and development to make them 100% dot legal and complaint with factory system.
You can add any brand of shock down the road really - ICON, King & Fox are all making specific shocks for lift kits that remove the big ass spacer.
My vote goes to BDS with the fox coilovers, fox rear shocks and leaf springs. You should be able to get the kit for about $3-3.3k shipped.
Sent from my SM-G900P using Tapatalk
I would go with a 20x10, on a 6" lift. I think the wider wheel would look really good. My 2 cents......
    Matt Parker
    Matt Parker
  • Who's Online   3 Members, 0 Anonymous, 840 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
