My Plasti Dip Disaster
I've never Plasti Dipped anything before. But I was looking for a way to customize my wheels. I researched vinyl wraps, but wasn't sure I could pull that off. I came across Plasti Dip and thought, yeah, I can do that.
So I did. The first wheel looked fantastic. Then I pulled the tape off and chunks of plasti dip came with it. :M16: Curse words flew fast and furious. I pulled it all off and gave up.
So my question for you guys is this: What did I do wrong? Pull the tape too soon? Too late? :dunno:
It was about 20 minutes after I sprayed it.
Currently soothing my broken heart with Lagunitas IPA. So I'll be ok. But I may wanna try again some day. Help me please.
Too late. WAAAAY too freakin late. Rip that tape as soon as you drop the can. And drop it. Don't set it gingerly. Drop it and rip.
Why not get them powder coated?
Mostly cuz a can of Plasti dip costs $5.89.
How many coats do you apply?
How can I do this when most everywhere I look says apply 4-5 coats?
Just go with one, heavy (riiiight up to the point of sagging) coat and pull the tape. This stuff is rubber, builds MUCH faster than water borne paint. If you're using tape, can't go with multiple coats as you found out. Trust me, works. I have stripes on my truck using this technique which have been on there going on two years now.
Pretty sure that's exactly how you don't apply PlastiDip.
First layer should be a light dusting. You can apply as many or as few layers as you want as long as you let each layer dry. Do not over saturate or else you'll get drips. I recommend 1/2 a can or up to one full can per wheel, depending on wheel size. Prep-work is vital.
Just use a razor blade to nip the rubber off the tape as you pull it off. I've done several vehicles and have never had a problem with this.
Atleast you make good choices in beer!
This is the look I was going for. So if I gotta go all around this with a razor as I pull the tape I'm gonna go insane. On the YouTube vids they just spray it, pull the tape, and bing, bang, boom it's glorious.
Can't figure out why I took chunks of Plasti Dip when I pulled the tape? Maybe I should just go powder coat.
I respectfully disagree. You can do it the hard way if you wish, but this is totally unnecessary. Dip does NOT spray like paint. It's aerosolized rubber. It behaves as such.
If you are going to use the dip edge technique or otherwise cut it, then sure, multiple light coats. But if you intend to establish a line with masking tape, pulling tape tape during the wet coat is the only way. Anything else is just risky or gonads and strife.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
