2015 exhaust and intake upgrade issues
ok
first off thanks for helping me out ,
I have a 2015 silverado with the 5.3 engine
first i did the borla cat back exhaust system
then I put on the K&N cold air intake kit a week later
well at certian times, you can hear a whine/growl coming from under the hood.
anyone else hear this??
did that huge stock intake hide sounds?
all I want to hear is im not the only one hearing this
Do you still have the flapper valve? if not, it is called droning, it happens when the engine is in V4.
It's the CAI. The stock intake is designed to reduce noise. I removed the CAI on mine because it was too much for me...much better with just the Borla exhaust!
On my previous 2 trucks this occurred after I installed a CAI and throttle body spacer, seems to be the norm with the setup. Almost like a poorman's supercharger/turbo noise.
I just bought a 2014 1500 w/ 5.3L and noticed the same noise coming from the K&N CAI. It's very odd since it makes more noise at low RPM and less up top when accelerating hard.
To the OP, what do you think of the Borla catback? Any drone when the truck switches into V4 mode?
The OEM intake tubes have what is known as a Helmholtz resonator. In simple terms, the intake air is pulsing because each cylinder intake valve is opening and closing. At certain rpm, the pulsing resonates with intake and becomes very loud. The Helmholtz resonator is a plenum that has a port into the main intake tube. The pressure pulses go into the resonator and bounce back and cancel the pulse. On the OEM intake tube these plenums are the square box-like shapes. Contrary to popular belief, they don't restrict flow/power.
so its not the flapper valve ?
whats a CAI
so it is what it is ??
CAI= COLD AIR INTAKE
I believe it is what it is.
ok thanks
someone told me of a custom tune to shut that feature off
anyone hear of 5star tuning out of SC
You can turn off the AFM or Active Fuel Managment with a tune, but the noise from a CAI or Cold Air Intake can only be solved with putting the stock intake box back on.
i was told the noise is the 4 cyliner shutt down
i was told if i turn that feature off the sound will go away
also a flapper valve
if im wrong just lemme know
i love the borla sound and peformance gains
    Matt Parker
    Matt Parker
  • Who's Online   3 Members, 0 Anonymous, 878 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
