BTW is the problem only there when the DRL is the only thing on or does it hair when the headlights are on as well?
Sent from my Nexus 6P using Tapatalk
Yes the drl only flickers when just the drls are on and the turn signal is used. Once truck warms up it works normal
Well huh.
Guess I will check mine tomorrow morning as well. One of those things you don't notice by yourself usually.
Might push me to look closer into getting that DRL to turn off with the turn signal like factory. It's just a small pain in the butt to get access to those wires all the time.
Only the bottom half of the drl turns off when the turn signal is on and only during the day in the new trucks
The whole DRL cuts off. This is why we've been trying to achieve it.
This sounds like interference but from how and where is anyone's guess.
Edited by zmnypit
I actually prefer the look of DRL staying on. I was wondering if trucks with the 6.2 are only effected by the flickering drl until it warms up.
Well I have a 5.3 and I just checked mine this morning with no flicker. Little after 8 and about 70 degree out. Was the first start after about 5 days of sitting.
Horacio and my truck are 6.2 and have flicker so maybe the electrical system has a more irregular voltage until they warm up
Same here. Haven't driven my truck since thurs afternoon and no flicker. It's been a year or close to it and no issues. His is only one side also. Passenger side is fine. :dunno:
It would be a non issue if the DRL cut out when the signal was on like it should, but I know that hasn't been ironed out yet.
Wait so your's flickers too? Payton34 has 6.2 and you have a 6.2. Hmmmmm
It will happen, just hang in there.
I ordered a Gen5 harness and will have it today. I will see if there are 2 capacitors in the wiring.
Fingers crossed! Maybe abominable Z71 will chime in on the 6.2L wiring. I see nothing but that isnt saying much.
Edited by zmnypit
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 776 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
