2015 5.3 LTZ
I have a tread but the search engine here does not seem to find it. I have what I quickly tuned tuned in as an exhaust vibration. GM tried to fix it early on but it came back.
My complaint was a noise and vibration at 30-40mph under light load. What I did not realize is how much vibration I was feeling at all other speeds and loads.
GM recently replaced my exhaust. Holly crap. I did not realize how much I would recognize the improvements it would make all ALL other speeds. I cannot hear or feel the difference in V4 any more. I don't feel the throttle pedal vibrate at all speeds. When I accelerate hard I don't feel like an injector is bad past 3k RPM. Seriously the engine shook.
Honestly I keep looking at my dash to see if I am in V4 or V8. The truck is smooth like a new truck is supposed to be. The drone is gone, small vibrations that I would not have tried to complain about are gone.
I have no idea what is different about the new exhaust. I posted this because in the Yukon forum they say a new exhaust is coming to fix the vibration problems. I used to hate this truck, it is really nice to drive now. I keep my radio off in disbelief of the improvement.
Could explain why so many trucks vibrate at the same speed range. Some of the other vibrations at other speed ranges could be slight variations in the exhaust.
Will be interesting to see how this might progress.
Edited by polarys425
Would be good to see a side by side comparison of the old & "new" exhaust, or to know what the difference is.
2015 5.3 LTZ
Do you know if they went exhaust manifold back? Catalytic converter back? Please provide some more details. Gas pedal , anything in steering wheel?
I can say i had the exhaust pressure in my truck adjusted once, and it helped for a while, but got worse again. I've heard rumors of high flow exhaust systems helping, but I haven't tried it so I cant say for sure. regardless, I sent a final repair notice to GM this past Monday.
They first adjusted my exhaust and the vibration went away for 300 miles. This time they replaced whatever amount is needed to replace the flap valve in the rear. I have a little more than 300 miles now with fingers crossed it stays fixed.
On a side note, do any of you hear kind of a "tinny" sound on acceleration from the exhaust? On my company's '15 6.2L Yukon XL Denali it has the sound under heavy acceleration and slight vibration of some sort.
In V4 mode the sound was very tinny, like ping ping ping. It is gone now. I hope it is gone for good. It is crazy how different the truck is now.
The truck is running like a sewing machine. I am nervous to jinx my luck. I have my radio off most of the time waiting to hear the crap some back. But so far so good.
  • 4 years later...
Same stuff happened to my 2018 Silverado there was a vibration in v4 mode they replaced the dampeners. There’s still a vibration but it’s very slight not like before but I’m still not satisfied.
  • Confused 1
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 420 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
