Catback Install (GM Borla) with Hellwing Rear Sway Bar
I just received my GM Borla dual side exit catback.
I crawled under the truck last night to eye up where I may cut the factory exhaust to remove it. I am looking at the 6" straight section of pipe after the muffler where it angles up over the rear axle.
I noticed that if I try to do a one piece removal that the rear sway bar will need to have the end links pulled to give me room to wiggle out the exhaust to the rear.
I then got worried that the twin tailpipe on the GM Borla catback will not clear the swaybar.
Has anyone installed any kind of side exit catback, preferably the GM Borla, with a Hellwig rear sway bar installed? I'd really hate to lose the swaybar just to install the exhaust.
How do you like the sway bar ? does it help, or a waste of money .
thetruck454 has Borla and Hellwig installed. He has the Borla dual rear exit though.
I have the Hellwig sitting in the box in the garage still. I plan to install it once I get all my exhaust figured out.
Sent from my SM-G930V using Tapatalk
I like the sway bar a lot. I think it really helped the handling. A couple of months later I also installed the Hellwig front sway bar too. I couldn't notice much of a difference from the factory bar.
I really don't want to have to remove the rear bar just for the exhaust.
I moved it bc it pertains to an aftermarket exhaust and sway bar
Thanks. I ended up double posting because I didn't know how to move it to the correct forum.
Members can't move topics only mods and admins. I make sure people will get the best traffic for their questions by putting them in the best sub forum possible
Thanks for the info. I contacted thetruck454 and he confirmed that the dual side exit Borla will not fit with the rear sway bar installed.
He did get the dual rear exit Borla to work but had to modify the driverside end link bracket on the sway bar to reposition the top of the end link closer to the truck centerline. Then he had to shift the spare tire a bit to the passenger side when cranking it up to its nested position.
I think I'm going to request an exchange of the dual side exit for dual rear exit. This little lesion learned will cost about $260 with restocking and added postage.
If using a rear sway bar, be very careful on the exhaust tailpipe configuration.
my corsa side exit hits the swaybar slightly when the exhaust has fully heated up and "extended" ironically there isnt really any marking on the pipes and ive never actually heard it hitting, just caught my leg on it one day walking by the back of the truck. im sure i could slightly adjust the exhaust and make it go away though.
truck is also a 6.2, and the exhaust is a full 3.5in, so food for thought.
Crap!
I have the sway bar installed, GM Borla side exit NIB (for sale section) and waiting for headers to show up to see how truck sounds before installing the exhaust.
Guess will be selling the exhaust for sure, the benefits of the sway bar are worth more, plus can always get the sound I want via a muffler change only which is what i should have done from start.
I passed on the front bar, not much bigger in size even though it is a lot beefier (weight wise) bar.
Crap!
Not sure what sound you're after, but I am very happy with exhaust now. Headers, ORY, OEM Catback with Borla 40359 Muffler in place of the OEM muffler and flapper. Left the resonator in place.
Since my exhaust is basically in the OEM position still, I shouldn't have any issues installing the Hellwig.
No problem!
I couldn't justify the price tag on a cat back for minimal gains and just sound. The borla muffler I want is $150. So lol have room down the road for a sway bar.
So you would replace the muffler only and leave the rest of the piping stock? Let me know how that works because I have to agree the cost is too much. I really did want dual back exhaust but not for 1500.
Sent from my SM-N900V using Tapatalk
Yes. If you look up YouTube vids about the borla touring and sport gmpp mufflers you will see. I called Borla and they recommended the gmpp to just replace the factory muffler but keep the flapper.
For those that want to see what I did to make the borla dual rear exit fit with the sway bar. It *may* fit with the dual both side exit, but there is no way it will fit with the dual same side exit. I also agree the rear sway bar makes an enormous difference. Between my sticky summer tires and the rear sway bar, this thing flat out rails for a 6,000lb truck
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,100 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
