Just signed up
Dcyphrz
Greetings GM fans! Found myself here many times over the years and thought I'd join. Lotta great information here. :)
Welcome. Good info here. Watch your wallet. It will sometimes make you spend money. So many good ideas
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
