Mine just got out the shop for this. They claimed it was my battery was real low and wouldn't charge. And my AMP steps which plugs into the port in the bottom of the dash. I'm just try and save money and ditch the truck. Putting a new die hard battery in it tomorrow and see if the problem happens again
Has anybody looked at corrosion on the B+ side fusible link of the battery. Mine was doing all kinds of crazy codes, stabilitrac, ABS, Traction Control, codes for fuel pressure system and one that really bugged me was '' Start vehicle battery low'' when truck was already running. Well cleaned all the green stuff off of the fusible link and added dielectric grease an ''BINGO'' truck runs like new.
I'm going to have to look at that and check it out. I checked the battery post before I scheduled an appointment at the shop. But the post on top the battery looked brand new still
I'm telling you man trade it in while you can.. I'm so glad I got rid of mine. The more I've read and the dealership service guy has told me, the 2014s are ridden with electrical issues.
That's what I'm leaning towards. New battery is in and if the issues come back this truck is gone. I hate to say it because I love the truck. But I can't have drive ability issues that can't be resolved.
Edited by Stallion225
Okay guys update on my problem. Was on the INTERSTATE today to see a movie out of town, had the ac blowing, radio on, wife rolls down window, then rolls it back up. As she rolls the up, I head a ding ding ding, looked at panel, says parking assist off, and radio volume stops working. Get off interstate, on the exit ramp, stabilitrac starts flashing on dash. So I pull off into the parking lot of the theatre, and as I'm pulling in, the steering wheel starts, once again violently jerking left to right ac turns off stabilitrac flashing, AND THE TRUCK DIES IN MIDDLE OF ROAD/PARKING LOT!!!! Texted my salesman going to try to bring truck in tomorrow morning. Somethings deff wrong!
Hi Phillip,
We are very sorry to learn about your recent parking assist concerns. This is not the experience we wish for you to have, and we would like to further investigate this situation. At your earliest convenience could you please send us a private message? We look forward to your response.
Best,
Brandon J.
GM Customer Care
Hi Stallion225,
We are happy to hear you love your Silverado. Your frustration is certainly understandable, and we apologize for the inconvenience this situation has caused. We strive to produce high quality products that we hope will meet your satisfaction, and this is far from the feedback we wish to receive. Should you have any future questions or concerns, please know we are only one private message away.
Sincerely,
Brandon J.
GM Customer Care
Hi Phillip,
Best,
Brandon J.
GM Customer Care
Why is it when there's a issue... you guys say I'm sorry? Just be honest and real... I'm sure you guys know a cure for all the issues... stop dodging bullets and release the cures. Edited by Silver ice 6.2
Recently experienced these same issues while driving on the freeway. In addition to the warnings that popped up in my cluster and on my info screen, my headlights would dim or sometimes flicker while driving. Definitely not safe and have to get this checked out tomorrow. The first message is the stabilitrak warning and the second is that steering would be diminished.
Sad. As others have stated. I have taken the truck in and they can't get it to act up. This is not something that happens on a regular basis. I took a picture of the mileage when I dropped it off and will be comparing it to the mileage when I pick it up. My wife agrees that if it happens again that we will be looking to get rid of the truck. If GM does nothing, not sure if I want another GM product. Still undetermined.
Went and bought a new F-150 today. I drive too much to worry about a computer or electrical issue. Thanks GM for not knowing how to fix your product.
I am dealing with the same issue. Stabilitrax light coming on and wheel jerking out of my hands. I took to the dealer and of course they could not duplicate the problem. I am worried about driving my family around in this vehicle not knowing when it will happen again. Has anyone found a resolution to this problem yet. I also have a clunking in the steering wheel which started happening just before the wheel started jerking and light flashing.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 391 Guests (See full list)
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
