12 hours ago, Kummie said:
Went to the dealer today and ordered the NEG cable - $210.00!!!!
Jeez! Anything special about it? Couldnt remove and just replace it with a NEG cable from AutoZone?
To the original question about "Service Theft Deterrent System"
From the manual, here is a start...
I have a 2015 Silverado and this just happened to me tonight. Got in to start it and wouldn’t start and a message came up service theft deterrent system. I was able to use the remote start and it started. From what I am reading it seems like a lot of vehicles are having the same problem. Has anyone figured this out? Is there some sort of reset that can be done?
  • 10 months later...
I have the same problem on 2014 Sierra.  Last year dealership, replaced ground cable.  Issue started again 2 weeks ago.  No consistency on what initiates the error.  Sometimes the auto start does it, turning key ignition does it and sometimes battery appears dead.
I replaced the fuse panel on the top of the battery.  Appears to fix problem but I will see.  All connections were tight but if I moved the panel slightly power would return.  If this doesn't fix it, i will have the positive wire harness replaced.
  • 6 months later...
I might have found a solution to this issue. Alternator going bad. I have a 2015 Sierra SLT 6.2L and I was experiencing at random times intermittent power loss when I would attempt to initially crank. Seemed like the batt was dead, I would then attempt a second crank and would start up just fine with a “theft deterrent fault” displaying on digital screen with a caution light. Radio would even reset. I’d then turn off and crank a third time and everything would be fine, no lights or faults on dash. I took vehicle to autozone so they can check the battery and alternator and of course their little pack said everything was fine but I still believed either or was the issue because I would also at random times experience hyper flash while using turn signals with all bulbs and lights illuminating fine. I suspected it to be an issue with the power supply system. So it eventually got to the point where I would get the theft deterrent fault more frequent on top of a “roll window” fault and my alarm system going off for no reason after unlocking car and opening door. Turn signals were hyper flashing just about at every use at this point so I knew whatever the problem is was about to hit its worst point. I then decided to check the battery voltage using a voltmeter with vehicle on and noticed that the voltage was only reading about 12v with a/c max and headlights and fogs on. To me 12v seemed a little low, my interpretation is that it should be +13.5v with vehicle on and alternator charging battery. Even tho autozone said battery and alternator was fine I decided to replace the alternator anyway because I replaced the battery a year earlier. After doing so, I checked voltage again. This time the battery was reading +14.5v with max a/c and headlights plus fogs on. No more hyper flash or issues yet. Been a few days since. Never received a battery light during this dilemma so I can see why no one has figured out a possible issue with alternator. Autozone was no help, lol.
Edited by Vpad89
On 11/7/2019 at 6:05 PM, Kummie said:
That's a great illustration, however, I don't have that on my 2015 Silverado 2500 HD on the upper console - darn it!!!
My 15 didn't have that switch either, but it only seemed to happen on HOT days.  Hasn't happened with my 18, yet.  I think, since it was "highlighted," that he was referring to the "Immobilizer."
  • 8 months later...
Last year, my power steering shut off while I was driving, 4 times in one day. A stabiltrack warning came on my dash.
I checked all fluid levels and all seemed fine.
Then for several months, no issues.
All of a sudden, it started happening again.
Now today, I could not start my 2016 Colorado.
The anti theft light is now on. I was able to jump it to get moving again.
I shut it down and let it sit for about 10 mind and it started up and the light was gone.
Chevy dealerships have not been able to help.
Any suggestions?
Any suggestions?
We are having this issue with a 2015 Tahoe. It will not crank on. It just clicks. And the theft deterrent light is on. We can’t get it to start now.
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
