What to wash with?
Just applied my second coat of Collinite 845 and my truck is gleaming. I read that Dawn dish soap tears off anything and everything wax related on a truck and it got me thinking about what else is ok/ not ok to wash a waxed vehicle with. Before I knew anything about this stuff I bought a big jug of Meguiar's Wash & Wax car soap. Would this be ok to use as a regular wash? Don't know if it will react with the wax on the truck or if it will be fine...
Edit: Also I've been using what's left of a bottle of Meguiar's Crystal wash and it seems garbage... after one swipe there are no suds and its like I'm washing the car with pure water. Any suggestions for super soapy stuff?
Thanks
I've used their Gold Class wash in the past with good results. Lately I've been using Adam's car wash soap.
I guess I'll try that. I used the Crystal wash yesterday like I usually do and the bucket was all foamy but when I went to apply it on the truck the suds were non existent. I got frustrated so I squirted another 4-5 ounces into the bucket and it got better lol. That's way over their specified amount per gallon but if that's what it takes...
Meguiar's gold wash - it does a good job also there wax's / spray wax .
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
