I have the same squeaking sounds on my 16 Silverado. It's due to the exhaust valve closing improperly and forcing exhaust back into the muffler and out thru the drain hole in the exhaust. The dealer has replaced my exhaust once already and that has not fixed the issue. They tell me there is nothing they can do because it's a design issue. This is all after 75% of the truck had to be repainted due to factory paint imperfections. Traded my '14 for this '16 big mistake so far.
Thanks all for the feedback. Since it's just the flapper I'll just live with it. Not really worth my time to sit in the dealership for 2 hours for something so trivial.
After reading the post above that mentioned how the squeak starts with a puff of exhaust out the muffler drain hole I tried a little experiment to plug up the drain hole. I wanted something that I could reverse and remove and wouldn't leave a trace in case I want to try and get a warranty fix.
I took some stranded copper wire and after stripping off the insulation I stuffed about 3 individual strands up inside the drain hole. I sort of bent it in a way that it wouldn't fall out. It made a difference. It doesn't squeak during light throttle when the truck goes into V8 mode but I still hear a little squeak when the throttle tip in is more aggressive.
So the jury is still out on this. I'm going to put some high temp silicone seal in the drain if the dealer balks at a warranty fix. I'm scheduled to go in for my first oil change in about a month so I'll update this thread with more info later.
Dale_K
My exhaust was replace once already under warranty. The new one has the same issue. The dealer should replace yours as well. I did notice that the loaners I was given did not have this issue. Both were '16 Silverados.
Had the same thing. My truck would squeal/chirp when it was in v4. Sound was completely random but would normally occur at lower rpm and would stop once back in v8. I recorded the sound and sent the clip to the dealership and they said it sounded like water in the exhaust???? I don't think so. At that point I already had the adapter valve pinned open which did not make a difference. I decided to replace the exhaust with aftermarket cat back and not go to the dealership every week just to hear they could not replicate the issue. The new exhaust solved the problem.
  • 3 years later...
I have a 2015 model and noticed it this year 2020.  Took a while to determine it was when the engine shifted from v4 to v8.  Has anyone found a solution other than the flapper valve and does it work permanently?
Wire open the valve permanently
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
    • From the spy shots, the front end does look like it's borrowing some styling cues from the Canyon. I'm more interested in the powertrain news than the screens though. If the 3.0 diesel survives into the next generation, that alone will keep a lot of current owners interested.
