2016 Silverado Firewall Hole?
Is there a hole on the passenger side of the firewall to run a power wire thru from the battery, I'm pulling off plastic now.
wee
Never run a power wire thru. Wire up a solenoid and run the ground wire thru. Much safer!
G
I had enough wire to go in at the driver side rubber grommet
wee
G
Really? lol
wee
  • 6 months later...
Bringing this one back to life. Where is there a spot to run some wires thru? I'm installing some Rigid Radiance pods and want to be prepared. I briefly looked on the driver side last night and didn't see an opening to the engine compartment. Thanks in advance
If you look by the driver side door upper hinge there is a black plug that you can route the wires through the fender (go in to the right of the master cylinder) and in it goes straight in the cab by the black box fuse box thing. That's what I did at least I just cut the plug and put the wires through and it is before the door seal
I drilled a hole just below the top of the carpet behind the brake pedal and used a GM grommet had in the toolbox.
