03-07 steering question
Son has an 03 Silverado z71. Have to replace a ball joint and tie rod end. When I ordered the tie rod end options were for gear steering or rack and pinion. So I guess some of these trucks cameveith rack n pinion steering then. Anyone ever swapped their old style gear steering setup for a rack n pinion?
I'm guessing the 2wd trucks had rack n pinion and 4wd gear box
2wd Trucks came with the rack
4wd Trucks have steering gears ( 33 and 34 spline units I believe im pretty sure the 34 spline is noted by the 4 bolt cover)
