Sierra All Terrain X Exhaust
  • Replies 55
Sweet. I may have this muffler chopped and replaced with a Magnaflow or something.
Could you post a video so everyone could here how it sounds please? How loud is your exhaust now? The magnaflow would sound really good too.
will do! i will record it tomorrow!
Her is a link to the Exhaust
No flappers that I can see. I dont see how this is called a performance exhaust when the muffler is the size of a water heater.
My Corsa sport muffler is huge too! I haven't measured it, but I'd have to guess at least 26-28" long
Wow, My exhaust is not even close to that. Is that from the dealership? no resonator deletes? What year is the truck
Sorry, I should've specified.....no not from dealer, it's the Corsa sport catback I put on myself. Eliminates the flapper and resonator.
It's actually bordering on a little louder than I would've liked...but great sound. Loudest on startup, but mellows in a minute.
My truck is a 2016 SLT with the 6.2L engine.
  • 3 months later...
The GMPP Corsa for 6.2 is 3.5" tubing...whereas I "believe" the GM Borla is no larger than 3".
Corsa will not give details however from all the posts I've read through on many forums one member said that an employee at Corsa said this exhaust was made for GM to be "slightly" louder than Corsa Touring but quieter than Corsa Sport.
If anyone is looking for a bargain Lingenfelter has some custom Corsa systems on sale for $59X.xx that were left over from custom trucks...these are however the lower tier systems and not the Pro. I believe they are named DB on Corsa website.
I've been researching these exhausts, wheels, tires, bed cover, subwoofer and a few other parts today for 2017 Z71 "Midnight Edition" 6.2.
I noticed the 2016 GMC Sierra All Terrain X package includes a performance exhaust upgrade. Does anyone know what's different about it?
I have the 16 All Terrain X. Different muffler I believe and no valve or resonators after muffler. here are some pics.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
