Going to tackle my oil pump
I'm going to tackle the oil pump on my wife's 07 Yukon Denali. We have an oil pressure issue at hot idle (10-15 psi) and I have done the "Cheaper fixes" first:
Oil pressure sensor
New filter/oil
Valve lifter oil filter
etc
I am not even totally certain its the pump, it could be the:
Pump
O ring on pickup
Oil Bypass sticking
Cam bearings
main bearings
etc.
With that said, the pump is my next step, and if I'm in there to replace the o ring I may as well put the $85 pump in too.
I am going to be following these write ups:
http://www.silveradosierra.com/vort...p-tube-replacement-advice-needed-t317794.html
http://www.ls1howto.com/index.php?article=4
but still have just a few questions.
One is reinstalling the harmonic balancer, I have read NO DONT EVER TIGHTEN WITH BOLT as it will strip, others say its fine, other say do it a little bit with bolt, hit with a hammer (w/wooden block) etc... <b>How did you do it??</b>
2) Does anyone know if the part number for the crank bolt and seal are the same for all LS style engines? I have part numbers on the ls1 write up but dont know if they are accurate?
3) The LS1 write up mentions dropping the oil pan an inch or two, is this possible on the AWD denali? I am going to try really hard to not have to drop the pan, because I want to avoid the hassle of the crossmember, steering rack, front diff, etc etc.
<b>Any other tips or tricks</b>? I plan on doing my thermostat when Im in there, and look forward to replacing some of my coolant as I dont know when it was last changed. After that we are on to new fluid in the transmission/filter.
Thanks
