Borla Pro XS & 6.2 exhaust diameter
Does anyone know if the 6.2 exhaust tapers down to accomodate a muffler with 3 in in & outs? I ordered the Pro XS but the largest they make is 3 inch and I am havin a bit of a hard time finding an exhaust shop that can bend the stock exhaust.
You can buy up and down adapter pieces. If you're shop doesn't have those or know about them, time for a new shop.
Sent from my SM-G930V using Tapatalk
Forgive my ignorance but I thought the stock 5.3 and 6.2 were both 3'' out from the headers. Is this not correct?
3.5 for the 6.2.
3.5 for the 6.2.
Good to know thanks.
Side question: If you are tapering down from 3.5 to 3 would you not be 'chocking' the exhaust and potentially losing HP? I am no drivetrain / engine expert so just asking out of curiosity based on stuff I have seen on Motor Trend etc. Or is it so minimal it is hardly worth noting?
That's a great question, and I'd love to know that answer with proven numbers.
I will say though, most likely swapping out the monster stock muffler for the borla at 3" is at minimum an even swap with a better sound.
I just remember an episode of Motor Trend where Dave Friberger was testing exhausts and noticed a difference between a 2.5 and 3 inch out same exhaust on LS engines. His conclusion was the 2.5 was chocking the exhaust a bit and the 3inch let if breath wide open. I am sure it is also very dependent on the engine and intake as well. Its was a minimal difference of ~10HP if I am remembering correctly.
Something like this: http://www.speedwaymotors.com/Exhaust-Reducer-3-1-2-Inch-I-D-to-3-Inch-O-D-,16215.html
Sent from my SM-G930V using TapatalkSorry, lol, last post. Great muffler choice, I love mine.
Yeah I guess I need to find a new shop. I wish Borla would make one with 3.5 in and out, I wonder what the GM Borla catback muffler has for input and output sizes.
Check out other companies has to be one that does. I am not about to talk smack about anything here but I had a Borla in my 06 Charger that I was disappointed with. Admittedly it was probably not top of the line.
Stock tailpipes
5.3 - 2.75" tailpipe
6.2 - 3.5" tailpipe
My 6.2 is 3.5" from the manifolds to the muffler and from there it's 3" back. That's stock. My old aftermarket exhaust setup downsized all that to 2 1/4" pipe. I chopped all that off and will be running 3" from the y pipe back. So long as you don't go anything less than 2.5" you'll realistically be fine. 3.5" won't fit for a dual a setup so 3" is the next best bet. Most people don't run an exhaust that big on gassers anyway so she should breathe great that way.
Just don't make the same mistake I did, check that piping and make sure it's up to par or at least close to stock size.
Borla has full exhaust for the 6.2 now . Im currently considering the Atak full kit for my 2016 6.2. I have heard one with it installed and it sounds very good . Its on the louder side when you mash on him but just cruising its low tone with a good sound. Also the exhaust with a tune is awesome!!
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 451 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
