bumper shields ?
  • Replies 45
First I've seen of he fronts. It looks really good. Was debating on getting the rear. Doesn't seem like a bad price for the front. The gloss white they offer is almost a dead on match to for he summit white color
I know the tears are available now. Was thinking about getting them till the fronts were available, but it might be cheaper for me to get mine powdercoated
I think they are okay at best. I don't like the seams you see on either side of the middle section either. For the price I think I'll opt for vinyl wrap
i call the company direct yesterday and ordered the front and rear in gloss black 472 shipped. shipping today so they are available
i had called about getting the bumpers wrapped. outragous price i was given $1500 . i must live in the wrong part of the country for vehicle wraps. thats insane
Yea I was quoted 225 a bumper for vinyl wrapping. Quotes 170 per bumper to powder coat. I think it makes sense for me to go powder coat then these. In your case though it makes sense for you. Post pics when installed. Anxious to see this!
i had been eyeing those front and rear for awhile, i think its my best option because im not sure there is a tungsten powder coat color, so i was thinking of getting the paintable version of those covers and have them colormatched
The powder coating place here doesn't have a summit white color to match. It's a different name but will look color matched when done. They are able to tweet the coloring to get it perfect. Should have it done in the next few weeks hopefully too
Why don't you just paint your bumper instead of of painting a boojie ass cover and sticking on your bumper? Then put some good PPF and call it a day. Cmon now [emoji849]
