New Member in Denver, CO
LAWLESS23
Hello. I would like to introduce myself to the forum. I am living in Denver, CO (moved from East, TN but originally from Phoenix, AZ). I just bought my 3rd Silverado (picture attached). It is a 2011 Crew Cab Z71 LT with a 2" RC level.
I am a member on another GM forum and looking to learn and share knowledge here too.
Thank you.
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
