gas w/gears or deisel
here's my dilemma. I have a 2008 2500 HD w/ 6.0 gas motor. It doesnt have enough power to pull my 15000 lb 5th wheel up steep hills. It has 3:73 gears in diff. Do I spend 1800.00 to switch to 4:56 gears or trade up to a duramax?
Yeah, I agree with KZ4. HD 6L is a good truck (I've got one, but with 410's), With the choice your thinking, go diesel.
... Or leave it, and run it.
That kind of weight, diesel would be the better investment of your money.
Diesel upgrade takes deeper pockets. Maybe you're good with that. Google it.
4.56 gears is a big step. They sing.
We have 4.10 gears, no singing. 2500 hd, 10.5x31 tires. Pulls well.
You didn't say how big tires you want to run.
Thanks for the input guys, I heard the message loud and clear. Went out today and bought a 2016 chev. 3500 dually, 6.7 /allison .its awsome. So is my wife by the way for going along with it. I'll install my 5th wheel hitch this week. BTW I'm new on this site also. From TN . Long time chev/gmc owner.
You gain in two important areas with a diesel 2500HD truck over your current gas powered one. First is in the power to maintain speed up a grade and to be able to pass more quickly. Second is grade control with the exhaust braking of the diesel engine teamed with the Allison transmission and it works very well.
I have dropped thousands of feet with a 4000 lb. load in my truck and on twisty mountain roads and the grade control working with the exhaust brake kept the speed down without my having to touch the brakes. The newer trucks (post 2011) have a new brake controller that can be adjusted to coordinate the truck braking with the trailer brakes if you have electronically activated brakes.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
